Question Gigabyte Control Centre bricked my monitor - please help
Nov 7, 2024
So I just purchased and hooked up the GS27FC
After looking up the model and installing the GCC software to adjust the monitors colour settings - the software is unable to recognize with monitor (I don't even think it's operating properly)
- When I initially hooked up the monitor to my laptop it worked perfectly fine.
  • After installing GCC, my computer now does not recognize this monitor properly. It will get stuck at 1024 x 768.
  • I uninstalled the software and it continued to persist.
  • I tried a bunch of different solutions to try and fix what ever changes this program did and just would not go back to what it was.
  • I eventually connected my laptop to a different monitor and it worked fine.
  • once i plugged the GS27FC to the laptop again - it now was back to normal at 1920 x 1080.
  • the but here is that it's now stuck at 60Hz. and If i restart my computer it reverts back to the stuck in 1024 x 768 mode.
My question is - has anyone dealt with something like this while using the GCC and if anyone has an idea what I can possibly do to try and fix this once and for all.
I would really love to not have to return this thing back to the store mind you cause it is at my office that involves a 1 hour subway ride ;_;
