I have a EP45-UD3R and I have the following problems
* reboot cycle at random times (power up for 4-5 seconds, turn off, power up again for 4-5 seconds, turn off) This doesn't always happen...
* When running memtest86 v3.5 with both sticks of ram (see hardware), the computer reboots after 5 seconds (45% into the first test, every time, exact same place). I've tried it with single sticks of my ram, and I have no problems after 10 minutes. I've tried exchanging locations, etc. nothing works.
* when installing vista with 2 drives on raid 1, vista eventually BSOD's while installing the OS. I've seen random errors just as PFN_LIST_CORRUPT and PAGE_FAULT_IN_NON_PAGED_AREA.
I've tried everything I can think of. Removed all the hardware, including the CPU (the cpu looks fine, no pins look out of place). Nothing seems to work.
In the BIOS configuration, I've not OC'd anything, just used to stock values, which matched the processor. except turn on the raid controller. (I tried both the Gigabyte raid controller, and the southbridge controller, to no luck)
Hardware
Processor: Intel Core 2 Quad Q6600 2.4 Ghz 1.35V
Fan: Stock CPU Fan
Memory: OCZ reaper 2x2gb DDR2 5x5x5x15 (I think the 15 is right)
Power Supplu: Antec 500 W. **
Graphics Card: Sapphire Radeon HD 4850
Hard Drives: 2 Western Digital Caviar Green 1TB Sata
** The power supply only has a 4 pin ATX power cord. I put it on the right most side of the bank of 8 and it does post, sometimes.
I've been struggling with this machine for days now. I've been looking for hours now on solutions, and I've seen lots of people talk about the EP45-UD3R and their problems. Their solutions run to 'Change the memory' or 'Power supply is wrong'.
Anyone have any clue on how to fix my problems?
Do I need to replace the memory?
Do I need to replace the power supply?
Do I need to flash the BIOS? (no idea which version I have right now)
or do I replace the gigabyte motherboard, and go for some other brand?
why is memtest86 dying in the same place every time?
why is Vista 64 bit exploding with random BSOD during install?
Please help!
Hardware
Fan: Stock CPU Fan
Please help!
