Hi,
I'm just wondering if the Gigabyte GA-970A-DS3P is a new stock version motherboard that is compatible with the AMD FX 6300. If it's not, how can I tell if it needs the update or not?
I've heard that the BIOS needs to be updated and if possible I really want to avoid having to do that update myself. I'm on a budget so if you could find me another motherboard around the same price that works fine with the FX 6300 I would greatly appreciate your help.
Many thanks in advance.
Link to the product here: http://
