Question Gigabyte MB front pins question
mrblint
51
I am building a system with a Gigabyte GA-Z270M MB and since this is only the second time I've ever built a PC, the last one being an ASUS about five years ago, I'm confused by the documentation for the pins for the front panel.
The docs say (p.15)
PWR_LED +
PRW_LED -
PWR_LED -
Why are there two negative pins for PWR_LED, and if I have only one such negative wire, which pin do I choose, if it matters?
Ideally you should have the -ve pin that is closest to the +ve pin to be populated and in a pair. The pins you're looking for are towards the far left in your manual and are labelled, PLED, not PWR_LED.
one negative pin is for S0 (LED on) (MIDDLE negative PIN)
one negative pin is for S3/S4/S5 (LED off)
Power stateACPI state
Sleep (Modern Standby)S0 low-power idle
SleepS1 S2 S3
HibernateS4
Soft OffS5
PLED/PWR_LED (Power LED, Yellow/Purple):
Connects to the power status indicator on the chassis front panel. The LED is on when the system is operating. The LED is off when the system is in S3/S4 sleep state or powered off (S5).
If you only have a two pin connector then only the Sleep (Modern Standby) will give a reading on the LED.
Reactions: mrblint
