Question GIGABYTE X299 AORUS Master constant blinking white light
Hi everybody. After plugged in bad USB hub in the USB 3.0 port, PC won't start. instead it constantly blink a white light and click sound. I disconnected everything and removed graphic card and memory. But the CPU still there. I THINK the power supply is good because i use the special plug to test it and the fan started. I also cleared CMOS. Is there a minimum i must have on a motherboard to boot? Like at least 1 memory stick? Should I try with nothing I mean take SSD and CPU out? I don't even get an error code on the 2 digits error code. I am not an expert like some of you. Please help! Thank you.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model.
How did you verify that the hub was bad?
I apologize for missing info. Because I mistaken a USB 4 port charging hub to just a hub. the hub smell a bit burning. Obviously i unplugged it fast but too late. So think i basically sent 5 volts to a USB port and short something. Very upsetting. $700 mobo. This morning i tested with a voltmeter pins from the power supply. All good. I took everything off the mobo and only connected system fan and tried. Same white light flashing. BUT here an interesting fact. The fan of the power supply works when I connect a jumper to the cable and turn it on. But plugged in the mobo when I turn on power supply, the power supply fan does not work. Any other suggestions? Thank you.
CPU: Intel BX80673I97980X Core i9-7980XE
CPU cooler: Noctua NH-D15, Premium CPU Cooler with 2X NF-A15 PWM 140mm Fans
Motherboard: GIGABYTE X299 AORUS Master (Intel LGA 2066/E-ATX/3xM2/Dual Intel LAN/ESS Sabre 9218 DAC/USB 3.1 Gen 2 Type-C Motherboards)
Ram: Corsair 15 32GB (2x16GB) DDR4 3200 (PC4-25600)
SSD/HDD:SAMSUNG (MZ-V7E500BW) 970 EVO SSD 500GB - M.2 NVMe
GPU: Titan V 12 GB
PSU: Supernova 1300 G2 (1 year old)
Chassis: Thermaltake View 71 RGB 4-Sided Tempered Glass Vertical GPU Modular E-ATX
OS: Windows 10
Monitor: TV
