This Question i feel could go into either the cooling section aswell but since im dealing withnthe fans and the bios i figured i would post it here
So First the Specs:
Motherboard: Gigabyte Z390i Aorus Pro Wifi
CPU: Intel I7 9700k {not overclocked}
Heatsink: Noctua NH-12Ls
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16
SSD: ADATA XPG SX8200 Pro 1TB 3D NAND NVMe Gen3x4 PCIe M.2 2280 Solid State Drive
PSU: SilverStone Technology 700W,SFX-L
GPU: Gigabyte Geforce RTX 2080 Windforce
Case: Lian Li TU150.
Case Fans: 4x Scythe Kaze--Jyuni Db 120mm slip stream.
So everything boots up correctly with the computer but for some reason the 2 bottom intake fans and the 1 front fan will spin up and then quit working . the CPU and Exhaust Fans work but the exhaust fan is super loud. i have both the exhaust fan and CPU fan connecteed through a splitter and the 2 bottoms fans are connected with a splitter. the front intake fan is connected directly to a fan header.
Ive went into the BIOS and messed around with the fan settings and it helps a bit but then it just reverts back to the 3 chasis fans just not working again. the cpu and exhaust still work.
i made a video aswell to maybe convey better what im trying to say.
View: https://www.youtube.com/watch?v=7t_KfmKfsuo
any help would be appreciated im at my wits end on what to do next.
So First the Specs:
