News Google now powering data centers with geothermal energy harvested using oil drilling techniques
You're going by gut instinct. This is an engineering problem not that different than sucking heat out of a CPU. The correct answer is arrived at via math and science - not a gut feel.
You are correct that there exists an answer, the problem is we do not have accurate enough measure to get to the answer. The article you linked to has no idea how long this would take, and has no idea if it would be successful even if they did know how long it would take. I snagged a quote in my last post. The size of the 2 magma chambers is estimated to be at roughly 55,000 cubic kilometers of magma. How much heat is exactly contained in the magma is unknown.
If more research is needed, then I'm sure it would happen before large investments were made, trying to implement the plan.
I just don't understand why we're messing with things beyond our control in the first place. I feel like there is potential for disaster as others have said.
By the sound of it, the risks are well enough understood and easily enough managed.
Let's be clear, nobody is about to just pull a cowboy move and decide to drop a tap into the heart of a supervolcano from out of the blue. There'd have to be a ton of further research and small-scale, carefully-monitored pilots, before anything was done at scale. Risks of actually triggering one would have to be understood and mitigated to virtually zero (if they're not, already).
