So everything was working fine the day before. Was able to play Witcher 3 for a couple of hours when suddenly a TDR timeout popped out in my screen. Assuming that it was a driver problem I uninstalled the driver I had (21.3.1), and installed a previous driver the website had (20.5.1). Everything worked out fine 'till the evening. This morning when I turned on the pc, my peripherals wouldn't turn on, that being my monitor, keyboard, and mouse. I tried restarting for a couple of minutes but to no avail. I read in a thread somewhere that removing the power supply cable from the pc and waiting for a couple of minutes would fix it and it did. But as I tried restarting the pc again the monitor, keyboard, and mouse wouldn't turn on again. I decided to remove the gpu and use the motherboard instead and everything worked. I restarted the pc again to see if my peripherals wouldn't turn on again but they're working now. Is it safe to assume that my gpu is the problem?
Specs:
CPU: R3 2200g
Mobo: Gigabyte A320m v1.1
GPU: Gigabyte RX 570 4gb
Ram: 16gb HyperX (8x2)
PSU: Corsair RM 650w
Specs:
CPU: R3 2200g
