Hi I am building my new PC. Here are the some computer components that I select.
CPU: i7 5820k
Mobo: MSI X99A Raider http://www.newegg.com/Product/Product.aspx?Item=N82E16813130866
RAM: 32GB (G.SKILL (4 x 8GB) 288-Pin SRAM DDR4 2400) http://www.newegg.com/Product/Product.aspx?Item=N82E16820232173
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147251
Hard disk: 1TB WD 7200RPM http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
Problem:
1. For GPU, so far I don't need powerful GPU, but I also plan to buy a GTX 980ti or Titan X when their prices drop down. Currently I have a Gallium 0.4 on NV43 in my old dell machine. Can I use this video card in my new build? I don't play games, and I only use this computer for coding and running programs.
2. Based on my build above, which CPU cooler is recommended? Notice that my case has three fans. Is it OK to choose some cheap coolers that under $50?
3. Suppose that I will add a GTX 980ti on my build, which size PSU do I need? 600w, 750w or 850w?
Thanks in advance.
CPU: i7 5820k
Problem:
Thanks in advance.
