[SOLVED] GPu doesn’t click in motherboard slot
The graphics card will have a tab that extends down into a gap between the motherboard and the back of the case. Try loosening the motherboard hold down screws a bit.
that should allow the motherboard to slide back a touch and allow the graphics card to fit.
later, you can tighten the motherboard screws.
Well that image isn't going to help with that.
Is your motherboard mis-aligned? On the standoffs (if applicable) correctly?
If you remove the motherboard from the chassis, does the card go in?
There are some tolerances involved, it could be you got a slightly larger card and the slot is slightly under spec. Only seen that once with some mismanufactured memory slots, and the board manufacturer was well aware.
