GPU driver problem
Josiah c-e
65
Ever since the latest windows 10 update my GPU drivers have disappeared. Every time i start up my pc the install manager for my r7 370 wants me to install the same driver, I have gone through the install process many times and it installs but then when I restart my driver is gone. Help!!
I would recommend you run Display Driver Uninstaller (DDU) from www.wagnardmobile.com. It will have you reboot into safe mode, where you can wipe your drivers clean and disable Windows 10's automatic display driver install. Then, when you reboot back into normal mode, you can re-download the latest drivers from the website and install them fresh.
When running DDU, you shouldn't need to change any of the default options, so be cautious when looking at them.
