Gpu fan speed only changes at 80%
Ronald_9
4
Hi.. I've been searching for solutions since yesterday but to no avail..
the problem is that, the RPM on my gpu fan only changes when i set the fan speed to 80%
10% 20% 30% 40% 50%.. basically n <80% rpm is always the same.
Rpm is always under 200rpm (is this even normal?) when not set to 80% and above.
Used speedfan, msi afterburner.. but results are the same.
I have a sapphire R7 260x 2gb
and here it is set to 80%
@rujoe,
The latest driver did not help at all.. I should also add though that this also happened with catalyst driver.. so i dont think that is the issue?
update pics after the latest driver(stil lsame):
under 80%
at 80%
