Hi,
Specs are:
Tech spec is:
Mobo - Asus x470F
CPU - Ryzon 2700x
AMD cooler Fan
PSU vs650
M.2 970 1TB
2x8 Corsair RAM
ATX silent case
GPU - Geoforce RTX 2060 Z Gaming
I opened my case to install a wifi/bluetooth PCI slot, that was fine.
I then had the idea to switch my GPU into the second 16 PCI as I needed to switch the wifi adapter into a different PCI slot. I then tried to start the PC but no display.
I switched the GPU back to its original PCI 16 slot and now it spins extremely fast and no display. Ive no way of getting display now due to the CPU I am using can only use the GPU's display (so ive read and its seems to be correct). Ive tried everything but nothing has fixed it. I havent yet tested the GPU on another PC because I dont have any other to test it on.
Strangely enough, my power button no longer works when I hold it down. It used to turn off the machine, now it just doesn't do anything,
Am I missing anything obvious here? Im stumped.
Cheers,
Specs are:
Tech spec is:
Mobo - Asus x470F
CPU - Ryzon 2700x
AMD cooler Fan
PSU vs650
M.2 970 1TB
2x8 Corsair RAM
ATX silent case
Cheers,
