GPU fans working at own will
u cnat spel
Commendable
Jul 11, 2016
17
Hello guys
My Radeon HD 6870 fans are working at own will, no matter how high the temperature gets, it starts and stops working from nowhere.
I already cleaned, uninstalled all fan control softwares, uninstalled driver with DDU in safe mode, tried different software versions and also tried without Catalyst Control.
GPU dying? Fans dying? Both?
What can I do? I cannot afford another GPU right now.
I also thought about plugging the fans direct on my motherboard, but can't be done.
Appreciate any kind of help, thanks a lot.
PS: I restarted the PC and HWMonitor is not recognizing the fans anymore. It doesn't even show up.
You can scratch all the post. The fans aren't working, and without them the temp reaches 105 in few minutes. No matter what I open, it'll end up reaching 105+.
Anyone knows where can I get these fans and if I would be able to install it? http://gpuboss.com/img/gpus/-9223372036847536085/9ac90a2df03ae7bf67397976a4edb970-400-256
last edit: Nvm boyz, I fixed it and it's better than ever http://imgur.com/RED69nV
Now I can play GTA 2 again.
Thanks ya'll!
