Hey guys, im going to be doing a build right after christmas and i have everything picked out except im stuck on my graphics card. i have a budget of $1000(can go 50-100 higher if i have to) and i want to be able to play any game out there and i want to have the best settings available, one game i will be playing for sure is guild wars 2. Its going to be my 1st computer for gaming so im really excited! heres my build so far:
CPU:Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
Mboard:ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
PSU:CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified
RAM:Mushkin Enhanced Essentials 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
HD:Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SSD:SAMSUNG 840 Series MZ-7TD120BW 2.5" 120GB SATA III Internal Solid State Drive (SSD)
Case:Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
So i have all of these parts in a cart on newegg.com and it came out to $772.93...im actually going to be going to Microcenter because there is a store close to where i live and im going to get all the parts there. ik theres dscounts on some of the parts listed so its not going to cost the same when i go to the Microcenter so if you guys have any suggestions on the other parts that would be awsome! i did a lot of research on all the parts so hopefully i did good
also as far as the case if there is a case out there that has a cear side panel that would be great cause i have been looking for one ad i couldnt find one that would fit in my budget. And also between getting an AMD or Nvidia card it really doesent matter for me.
