OS: Windows 11
GPU: ASUS TUF Gaming RTX 3080
CPU: AMD Ryzen 9 5950X
Motherboard: TUF GAMING X570-PLUS WIFI
PSU: CORSAIR RM1000
RAM: 4x 8GB
ISSUE
My PC has been having graphical issues the past few days that came out of nowhere.
I had my computer on the desktop screen and I wasn't running anything on the PC, I look up and there are these green (on one monitor, blue on the other) squares on the screen and am unable to move the mouse or get any output from the keyboard/mouse. The PC then blue screened but happened so fast that I couldn't see the code before it crashed completely. I restarted the PC and it booted now with white lines across the screen and one monitor that wouldn't get singal. so I reset it again to see and it turned on fine but all I had to do was wait about 5 minutes then the same problem arose. Came back an hour later after trying all methods below and opened Farcry 6 since it's graphically intensive and left it on pause for 30 mins, came back and PC was still on but as soon as I moved the mouse and the screen updated then it all happened again.
DIAGNOSIS
I proceeded to reseat the GPU, reset CMOS, reseat the RAM, try the second slot in the motherboard but all to no avail.
Also tried putting the GPU into my roommates rig which it worked but proceeded to hard crash when trying to load a game which could have been from his oc setup, I don't know. but the PC would then not boot and would give a 9E error code on the MOBO.
Put it back into my PC and still having the same issues and want to make sure it's the GPU or anything else that i could try before I decide getting a new one.
IMAGES
View: https://imgur.com/a/605Oiep
PSU: CORSAIR RM1000
RAM: 4x 8GB
ISSUE
DIAGNOSIS
IMAGES
