Some days ago i posted a thread here about my monitor not getting signal from my GPU. Tldr: whenever i set the monitor to DVI i just get a black screen. I have installed a SSD a few days before. It worked for two days and i had restarted the PC multiple times, but when i restarted that one time, the problem happened.
I bought a new DVI-D cable that arrived a few hours ago, but the problem persists, so i guess the cable is not the problem.
Since i'm using the motherboard entry, my GPU is "invisible" to both systems (W10 and Linux). It does not appear on Windows device manager, and i cannot install any drivers for it. Linux device manager shows a message saying that i do not need to change the drivers instead of showind the drivers installed. I also noticed that on BIOS, the CPU fam seems normal while the second one called "SHA1 FAN" is giving an N/A.
My specs:
Motherboard: ASUS PRIME A320M-K/BR
CPU: AMD Ryzen 5 2400G (using Radeon RX Vega 11 Graphics as integrated graphics)
GPU: ASUS Nvidia GTX 1050Ti
RAM: 1x 8GB
HD: Toshiba 1TB (with Linux mint 21.2)
SSD: Kingstom 960 GB (with Windows 10 22H2)
PSU: Thermaltake smartseries 430W
Monitor: SAMSUNG S19C301F
What i tried:
- Factory reset the monitor configuration.
- Turn off the pc, unplug it from the power supply and press the start button during 30 seconds.
- Make the monitor had manual detection instead of auto. I had both VGA and DVI cables plugged at the same time. The VGA works, but as soon i change to DVI, the screen goes black.
- Uninstalled the GPU drivers using Display Driver Uninstaller on Windows. It also deleted nvidia experience.
- Bought a new DVI-D cable.
- Updated the motherboard BIOS to latest version.
I know this topic is about the GPU, but there is a chance that the SSD is the culprit? Not the SSD itself, but maybe i managed to mess something during the installation, but this seems unlikely because it took 2 days for the problem to appear.
My specs:
RAM: 1x 8GB
What i tried:
