[SOLVED] GPU not using full power
Sep 5, 2019
4
Hi chief
I recently bought a MSI GL 63 8SE with RTX 2060
but I noticed that while gaming the computer does not use its full GPU power and it only uses about 50% to 60%, tried to change the windows power-saving and stuff, but did not fix anything... really do not know what to do more, appreciate your help.
Cheers
This begs the question....
Are you maxing out the GPU?
If you are running games that only need 50-60% usage you are only going to see 50-60% usage.
For instance.....if you are running at 1080p 60 fps (Vsync let's say) on ultra.....an RTX 2060 isn't going to max out on many games.
