[SOLVED] GPU Replacement/Upgrade Help
zak.littlechild
Commendable
Aug 11, 2018
36
So, brief explanation is im currently saving for a PC, but at the same time while saving the money to buy said PC, my current rigs GPU has died, so I thought if I replace that now, I can just use that in the new rig and save up to buy the rest when I can,
So now im torn between the EVGA SC 1660 Super, - https://www.scan.co.uk/products/evg...r-ready-graphics-card-1408-core-1830mhz-boost
or PowerColor AMD Radeon RX 5600 XT Red Dragon - https://www.scan.co.uk/products/pow...cie-40-graphics-card-7nm-rdna-2304-streams-15
Having done some research I have seen a few horror stories concerning the 5600XT Red Dragon, so does anyone know if this has had a bios update and has fixxed the fans/overheating issues?
Never used an AMD GPU so any advice is appriciated
Current rig:
i5-4690k @ Stock
Asus Z97-P Mobo
EVGA GTX950 SC (dead card)
TX650M PSU
Furture Rig: https://uk.pcpartpicker.com/list/njx2x6
you have a very old cpu and this could be a problem buying a new gpu which could be wasted.
you should look for an used card to have something immediate and save something .
the good card you should buy it when you have the new build :)
Yeah I know the CPU is showing its age, but I will have the build up and running by end August/Mid Sept - so thats why I thought just buy the card now as I can afford it, and use that for 3 months
