[SOLVED] Grains on texture and shadow issue.
DitherOl
Greetings,
I bought my RTX 2070 few weeks ago and since then, i've noticed some issues related to game's image quality.
Videos:
View: https://www.youtube.com/watch?v=5S_GUgkA_tM
View: https://www.youtube.com/watch?v=KxHVkosFboA
View: https://www.youtube.com/watch?v=15Af9w5quNw&feature=youtu.be
View: https://www.youtube.com/watch?v=MjfwMNeJ0aE&feature=youtu.be
View: https://www.youtube.com/watch?v=be2JzHoB_bY&feature=youtu.be
Screenshots: View: https://imgur.com/a/oCGBxS9
Stress test: View: https://imgur.com/a/L1P9Lf7
View: https://imgur.com/a/jwH6RFB
As you can see in the videos, there're many graphical issues, as well as shadow flickering, that can be noticed while camera is in motion. Sometimes, i can also observe issue related to level of details. I've already tried many drivers, as 419.67, 436.15 and 436.30. Every driver was installed after total uninstallation via DDU.
System's configuration:
GPU:
ASUS GeForce RTX 2070 ROG STRIX A8G - 8 Go, hasn't been overclocked
CPU: Ryzen 5 2600 3.4 Ghz, no overclock
Motherboard: B450 GAMING PRO CARBON AC (MS-7B85), BIOS/Date - American Megatrends Inc. 1.60, 06-03-19
RAM: Corsair Vengeance RGB pro 16GB (2x8GB) DDR4 3000MHz, XMP enabled
PSU: Seasonic Focus Gold 750W
Operating System and Version: Windows 10 Home 64 bit, 1903 version, clean install
GPU Drivers: 436,30 version, clean install
According to stress test, i didn't noticed any issue concerning my GPU, so i suppose the problem isn't caused by it. However, someone told me that RAM instability or videomemory can actually provoke these issues. In contrary, other people say that it's caused by RayTracing rendering technology, so there's not any fix that could solve this problem.
What do you think? Should i actually return my RAM or even SSD?
it looks pretty much normal to me, nothing is perfect
tho noticed on 2nd vid u got some microstuttering there, this should be vsync related as this game has frame lock which likes to run out of sync with gpu driver
crew 2 flicker shadows alot, its proly game engine fault, set shadows tto off, problem solved
As for shadows in The Crew 2, I agree with your reflection, that's probably engine's fault. Concerning Assassin's Creed texture problem, I wouldn't say that this is something normal and usual. That's true, the video just can't transfer issue as i see it on my screen. But belive me, these artifacts are clealy seen on my screen what is very disturbing.
Latest posts
