Graphic card help
johnclean
Hi i am trying to fix my PC to be able to play few games like Payday 2.
recently my PC started to freeze for some reason after i opened it to check what RAM i have (2x1gb, 1x2gb) and i just brought payday2 and i lag during game.
Here is my PC
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01125222&tmp_track_link=ot_faqs/top_issues/en_uk/c01125222/loc:2&cc=uk&dlc=en&lang=en&lc=en&product=3542411#N176
I changed my Grapic card to SAPPHIRE HD 5450. Net speed 7-10mb
What changes do i need to make to play these games please
Hi,
What do you mean by check the ram? Was it not working to begin with?
That isn't a very good RAM configuration.
Your system takes DDR2 ram = DDR2-800 to be exact.
The GPU may be okay for older games.
If you are lagging during games, it is most likely your CPU or GPU causing the problem. RAM does come into play as well.
This isn't a preferred setup: (2x1gb, 1x2gb)
This is 3 sticks of RAM. You want to go with two as Kohwali and I have said.
Take a look here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231207
Your PSU is very weak @ 300w. I normally wouldn't recommend a Corsair CX model, but this is an inexpensive option:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028&cm_re=corsair_cx_600-_-17-139-028-_-Product
Your CPU should be fine according to the Payday 2 recommended system requirements. The GPU falls short of the recommended specs.
http://www.systemrequirementslab.com/CYRI/Requirements/payday-2/11686?p=r
If you go for the PSU and RAM upgrade, here is a decent GPU to work with it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202050&cm_re=Sapphire_R9_270x-_-14-202-050-_-Product
These parts add up quickly, so if you have to choose an upgrade, go for the RAM and the PSU first.
Hi Sorry i am not very good at this i know to change parts and all that but just need understanding of what.
- I found 4x2gb RAM 8mhz for £40
just need understanding of what i will need to change. from what i have gather Just PSU and RAM
