Hello!
I have been googel-ing for about 2 months now and still have the same problem.
My Computer shuts down while playing Skyrim / Dota 2, but not while playing CSS:GO at least not as often.
When it does shut down, power goes off an the screen says Entering sleep mode, then it restarts.
__________________________________
Windows 7 event log usually goes like this
The operating system started at system time 2013-01-03T21:14:17.484375000Z.
File System Filter 'FileInfo' (6.1, 2009-07-14T00:21:51.000000000Z) has successfully loaded and registered with Filter Manager.
The previous system shutdown at 10:13:19 PM on 1/3/2013 was unexpected.
Microsoft (R) Windows (R) 6.01. 7601 Service Pack 1 Multiprocessor Free.
The Event log service was started.
The system uptime is 9 seconds.
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Processor 0 in group 0 exposes the following:
1 idle state(s)
5 performance state(s)
8 throttle state(s)
Processor 1 in group 0 exposes the following:
1 idle state(s)
8 throttle state(s)
and on to its 7036 ID routine...
I also put the graphics card on a Build in stress test by FurMark, which i didn't leave to finish, because the temp was starting to approach 100° heat (GPU-Z sensor log), and when the game crashes my heat levels for GPU were around 60° (EVGA Precision) with all settings on low and windowed mode with processor heat levels same around 60°-70° (Core Temp)
All comments are welcome and additional info can be given!
1 idle state(s)
8 throttle state(s)
1 idle state(s)
8 throttle state(s)
