This was my original post last week:
I brought a 650xfx PSU and another 550gtx, thinking if it was my PSU or GPU was faulty I'd either get an straight upgrade or been able to send back gpu and get one a little later, however it's not the PSU or GPU causing the problems I've stated above. So Mobo, ram or CPU? Thanks again
I've had my PC about 3weeks, Everything has been working fine so far, for the last couple of days I've had graphical errors. When ever I view an image on a website it has green, red and blue dots random on it, if the webpage is built using images it's all over it, however if I open an image on my desktop all is fine.
Videos don't work as they should either, whether it's youtube or played through VLC, wmp etc the same happens but with horizontal blank jittery lines and shockwave flash crashes quite frequently, Videos played through a media player won't crash but will be unwatchable due to the dots flickering and the black lines.
Games have this weird flickering some objects will appear to disappear for a slight second them come back making objects look like they 'flicker', this happens more often in cut scenes then in actual game play, but still happens quite regularly, I also have a 'crackeling' sound in my headphones in all games, it's not constant but it's there and it's ONLY in games.
It all started during a session of swtor where I had some connection errors and CTD, as I looked for solutions online I started to notice these errors, Now games like FIFA 12 will CTD, GTA will have bad flickering same as sc2 but skyrim runs perfectly. I've also tried installing a fresh windows and the same problems occur.
My gfx card wasn't OC, I thought maybe a down tune would help the problems and if I try to even open ntune, the 2nd I do my PC will blue screen, my PC specs are:
i52500k 3,2ghz (oc to 4,2)
asus p67mobo
8gb corsair vengeance ram
gigabyte 550 ti gtx
I have no idea what to do, I think I've just got a faulty graphics card but wanted some advice before I sent it back, thank you taking the time to read my problem & any help is greatly appreciated.
