Graphics card dimensions and Thermaltake V4 case
Wakers
11
The max length for a graphics card, according the thermaltake website is 10.5" (267mm).
Sad thing is, a lot of 7870s and nearly all 7950s appear to be longer than this. Has anyone got the same case and managed to fit a bigger card than 10.5"?
If I look inside the case, I appear to have quite a lot of spare room between the drive bay and my Gigabyte 6850OC.
Thanks for the help!
I have the same case and my 660ti arrives today. I think the size on it is 10" I was taking a look last night and it looks like it would fit toward the bottom - of course depending on your PCI-E slot locations. Mainly due to where the 5.25 internal slots and the 3.5" are stacked below it.
Yea, thanks for that. That's really helpful.
Maybe you should use your brain next time and attempt to figure out if someone is not just asking for the obvious answer.
