hi, i'm in the search for a 128DDR, 128-bit 8x graphics card. I have to say that the money exchange rate is not favorable for imports here(third world country far faaaar away), so you will see by those prices that buying at a local computer store is basically a rip off, thus, my originally low budget gets even lower. Given this, i need to get the best deal under U$s200 and so far this is what i got:
Albatron FX5200P 128DDR 250/500/4ns 4L DVI/TV U$s 145
Albatron FX5200U 128DDR 250/700/2.8ns 8L DVI/TV U$s 195
Asus v9520/TD GeForce FX 5200 with TV-out and DVI U$s 165
ATI Radeon 9600 128 DDR DualHead DVI/TV out U$s 194
ATI Radeon 9200 128 Mb DDR DualHead DVI/TV out U$s 130
ATI Radeon 9200 128 Mb DDR DualHead DVI/TV out Box U$s 192
Gigabyte ATI Radeon 9200 128 Mb DDR ViVo Box U$s 142
(i think the 9600 is from shappire but im not sure if its pro)
Please i need your help to decide, i think that,with this budget cards, minor differences in performance are noticeable so i really want to buy the best for this price range
-Which one do you think is better and more stable?, i'll use it for 3DStudio max 5.1 and photoshop.
-And i'll probably buy it here, unless i take the chance of online shopping overseas, do you think its a good idea, whats your experience on that, can you recommend me an online store that ships internationally?
thanks for the help
my specs
*Albatron KM18G Pro Socket A FSB333 DCh400/Video+TV+AGP8x/5.1/lan (Gforce MX420 integrated GPU)
*AMD Athlon XP 2500PR 512K Barton Box
*DDR 400 Mhz PC-3200 OCZ Premier 512 Mb
*Maxtor DiamondMax Plus 8 40 Gb ATA133
*Medium Tower Vitsuba 400W
thanks for the help
my specs
