[SOLVED] Graphics card problems
Jan 24, 2021
Hi I have a rx570 4 gb and a rx 580 8gb the problem with the 570 is it's detected by the computer but the radeon program pops up saying no graphics card detected and says it needs open gl 2.0 or later I open up gpuz and the card is there with it's info but no memory info or temp .. fan.. that's what is wrong with that one I have tried installing old driver's and new ones and flashing it but nothing..and the rx580. The same but when installing the driver on win 7 it will go all the way threw but when restarting it gets bsod and on win 10 the same
full system spec? include make and model of the psu
use gpuz to check both gpu?
Used gpuZ and shows no info
Using old stuff to build a rig it is
Psu.. corsair 500W
Ram..4gb ddr3
Processor..dual core 3.0ghz
Motherboard.. gigabyte
Took it to a shop with newer parts and the same thing it can't be the psu or board
I installed the driver and previous drivers and showed up but the GPU clock and memory stay at 0 and the temp and fan speed they then the next day no video at all so I took to a different tech shop and he said it needed reballing that's why no video and said it didn't let it process the memory..temp..GPU clock..fan speed
