Graphics card that will play WOW at max settings
solance
40
8800 GTS 512 should max it out at 1920*1200 - no idea what power supply your HP uses, but I think 400watt with good amperage on 12v is the minimum for 8800 GTS 512
8800 GTS 512 should fit in even a cramped HP case too i'd say
I'd get a second opinion though from someone more familiar with HPs
depends on the resolution the ram onboard - if your playing 1900x1200 you want an 8800GTX or the newer 9800GTX has less ram
the new 200 has 1 gb
the high the resolution the higher the ram needed
my customers play wow at 1900x1200 with the 8800gtx
Aye well the case currently only has a crappy 250 w power supply but ill be upgrading it (also looking for suggestions on PSU) but how would the 3870 fare?, or the 9600 GT? and currently i am not looking to run at 1900x1200 as i dont have a BBM( big beautiful monitor) yet but i do have plans to get one so i might as well plan ahead for it
I don't agree with that video card suggestion if you want to be playing with MSAA enabled
MMORPG's are notorious for getting graphically bogged down when there are many players on screen which is not uncommon. I think the 7900 GS would not give a universally acceptable experience at all times.
MSAA doesn't help wow. perhaps if he was talking about Age of conan. at high enough resolutions even AA is barely noticable. In fact I would even suggest the ati 2600. He doesn't have a large screen and all prior suggestions will prolly cook themselves in a stock case.
I would get this ati 2600. It's larger cooling solution will dump air outside of your poorly ventilated case.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1305520549+106792278&Configurator=&Subcategory=48&description=&Ntk=&srchInDesc=
And for anyone doubting the power of the card here is an interesting watch.
http://www.youtube.com/watch?v=-mki3VupOxQ
In large towns such as iron forge or ogrimmar during peak hours your connection to the server will most likely be the cause of any "stuttering" you may see. Back when there we're town raids the servers crashed before my x800xl could unleash it's full potential lol.
I have a X850XT, a X2 4800+ and 3GB Ram. I played wow max settings always above 35 FPS. With a crapload of addons.
WoW is very well coded and overall a very light game. The only stuttering there is usually server lag. Get a 2600 or a 7900, put one or two more Gigabytes of ram, and that is it !!
Even in "Old" Alterac Valley during the turteling sessions it would fly. Same in 40 man raiding. Yeah i'm old school. I was i mean.
It would do pretty well, yeah. If you play anything else that is more graphically demanding though, I would go with something a bit more powerful (like a 9600GT). For WoW alone, the 9500 should do fine.
In such places, your video card will be bottlenecked by possibly your CPU, and most likely your connection, where a less-than-perfect connection will cause a domino effect, where the CPU will struggle to detangle things, resulting in it bottlenecking the graphics card.
For WoW alone, the 9500GT should be sufficient to max out the game to probably at least 1680x1050 without any drop below 60fps attributable to the graphics card itself.
You may want to consider a 9800GTX. Like other people have mentioned, any area that has a large number of people (such as Shattrath, Orgrimmar, or Ironforge) will tax your video card. I have a system that scores a 18500-19500 depending on my OC with 3D Mark, but still drops to 40FPS in crowded areas.
Also, don't worry about your network lag. That does not play into the FPS rendered in WoW.
The 9600gt will destroy Wow, and keep you gaming for a long time in general. Especially if you have a low res monitore. Even with AA and the what not.
There is absolutely no reason for a 9800GTX for WoW at 1024x768. In fact, there is almost no need for a 9800GTX for ANYTHING at that resolution except Crysis with AA.
I have max settings on WOW with a Q9450 & XFX 8800GT -YDE4 model (512mb), Using a comcast cable modem connection in 1280x1024 I run at 60FPS in all Cities/Raids. It is soooo nice to play the game with all the eye candy on and not have any graphical issues. I am going to put a 9500GT in my old ladies comp for WOW, she doesn't raid (even though it would be fine and this card could handle it), she just runs around the world and talks to people while questing.
Although I agree WoW isn't very demanding, I found anything below an 8800GT 512mb won't do it for you. Even then you'll run into low 30s in Shattrath(1920x1080) with max graphics. For your low resolution I would still go with an 8800GT to be safe.
