I have a GTX 960 and wanted to put it in a HP Pro 3500. The graphics card is the 2 fan EVGA GeForce GTX 960 2gb version. Will it fit in a HP Pro 3500?
Okay thank you I am going to get a 500watt psu with the 8 pin connector I need for the card.Fit yes, but it wont' work unless you update the HP's power supply. The 960 typically requires a 6 pin PEG/PCIE connector that the HP PUS doesn't have.
