for the last few months i have been getting a repeat crashing of my games it seems to happen when my gpu gets to a high load.
ive tried so many things and wondering if you have some idea what the problem is as im thinking that it is hardware not software related.
Here is a list of what i have done:-
updated ALL drivers(used ddu to remove old GPU ones)
updated bios
re seat RAM,CPU,GPU
unplugged all cables and plugged back in correctly
new thermal paste on CPU
added a TdrDelay of 8 (in the right bit for my OS)
Bought a bigger wattage psu 600w (500w recommended for current GPU)
bought a new graphics card went from asus gtx 1050ti to an aorus amd rx 580
re installed windows about 3 times now
i am completely out of ideas. wondering if there is some way of finding out what is causing my problem as i do not really want to spend alot of money rebuilding a whole pc if its just 1 piece of hardware.
i hope you can help as this has been a headache and im very keen to fix it as i cannot game atall with this consistent crashing
thanks.
updated bios
re seat RAM,CPU,GPU
thanks.
