[SOLVED] Grinding sound coming from desktop
Feb 27, 2021
A grinding sound is coming from the inside of my desktop case. It isn't noticeably affecting performance, but the sound is annoying and I want to address it in case it actually is a problem besides just the noise. Some suspect it is a fan issue, but I am skeptical from prior experience.
This is the current unidentified sound coming from my desktop
https://drive.google.com/file/d/1XB-HWkGemFQ3IQdQMj1WnN8vvCTXY0dq/view
Last year I had a sound coming from my desktop that turned out to be an issue which I resolved by replacing a malfunctioning fan. It sounds noticeably different in comparison.
https://drive.google.com/file/d/1tA2ZHV5Njns_peaARk2ZwrjSJ_NerV3s/view
Thanks for any help in troubleshooting.
This is def a fan. Could be the fan itself or something touching the fan blades.
You just have to open your case and touch the middle of each fan to slow them down a little until you find the fan doing this sound or you can see if something is touching the blades.
I never heard a HDD making a noise like that so it's not the HDD.
It has to be a fan. That's the only thing left in a PC that is moving.
Could be the PSU fan too.
i've heard a lot of malfunctioning fans and drives through the years and that's not typically the sounds they make.
it sounds more like an obstruction that may be rubbing against a fan's blades. possibly a very light cable or paper tab?
if you probe the entire layout of the case and find nothing,
maybe try just giving the outside of the case a light wack🤜.
it is pretty easy to determine if it is a fan or not.
just stop each fan one at a time and see if the noise stops with one of them.
lightly press on the middle section and they will stop without much pressure.
I do not think it is a fan issue but brought that up because people suggested that. Adjusting fan settings in SpeedFan does not stop/change the noise. With the prior issue I had, changing the settings with that software would alter the noise.
"adjusting" fan speed or actually stopping them?
but, like i stated previously;
