GTX 1060 6gb problem! help asap please
Kain_2
39
Hey i was running a gtx 1050 ti 4gb and it went well, then i thought it was time for a upgrade so i jumped to a gtx 1060 6gb and after installing it and playing games i noticed my case was getting super hot so i took the side panel off, made sure all the fans were working and its still hot? its only sitting at 50 - 60 degrees which is fine but i have my side panel off, and 4 fans running and the gpu is burning hot! i touch it a tiny bit and my hand burns and its only when i play games, its cool when doing normal tasks
Burning hot is only something that you feel, these are electronic components they are burning a lot of energy which comes out as heat.
So yes it's fine, stop touching it until it hits 85 don't be concerned. So put the car w back together and enjoy it.
these gpu temps are perfectly fine
but dont touch them because they are hot for a hand but good for a gpu
