GTX 280 power consumption
chatman2222
5
Hi, I am currently thinking about upgrading to a GTX280 and and worried if my PSU is beefy enough.
I currently have an antec 650W psu.
My build is:
Asus striker extreme
Intel e4400 OC'ed to 3Ghz
320mb 8800gts
2GB 6400 corsair ram
x-fi
500gb HDD
Ask if i've missed something..
So i'm worried that my psu might not be enough for an upgrade from 8800gts to GTX 280.
Thanks in advance!
Allways remember that the wattage written on the box is not worth alot.
You need to find out how many Amp´s the PSU is yielding on the 12V rail.
For example:
PSU 1 :12V rail with 18 Amp = 216 Watt
PSU 2 :12V rail with 30 Amps = 360 Watt
If you then have a GTX 280 which eats up close to 300 Watt under load, then PSU 1 isnt powerfull enough.
And if the PSU doesnt have 2 x 12V rails, then the one it does have is powering both GPU, and on ATX boards also the CPU.
get a gtx285 because then it will only use 2 6 pin pci express cables rather then that weard 8 pin one that needs 2 6 pins just to convert it. Also the 285 is a little less power hungry
