GTX 560 Ti 2GB - Possible driver problem and crashing on Win7 64bit
mrmaia
598
Good morning guys
Yesterday I did a fresh install of a brand new computer and it was working fine. All of a sudden (after ~5 hours of use), my system froze and the video went all crazy (actual photo from my monitor):
In this first freeze, the computer did not respond to anything for like 2 minutes, and then I rebooted it. The POST and the EFI display fine, then in the Welcome Screen the system crashes again, but now after 1 min it restarts.
To isolate the problem source, I ran a series of tests:
• Ran the computer on Safe Mode. It ran nicely.
• Then I turned iGPU on and plugged my computer to the onboard port. Ran nicely again (although the max res I could get is 1280x1024, which looks horrible on my 1600x1050 monitor).
•Then I uninstalled all the Nvidia drivers and let Windows install its default drivers for my GPU. It ran nicely once again.
This makes me think the problem is exclusively driver-related (i had installed Nvidia drivers 266.58, 275.33 and 285.62 and none worked). Funny is, even with the drivers installed EVGA Precision says it has detected no hardware and Virtu says it can't turn on.
My system configuration is this:
EVGA GTX560Ti 2Gb
Windows 7 Ultimate 64bit
Asus P8Z68-V Pro
Samsung SyncMaster 2233
Intel i7 2600k @4.0Ghz
16Gb Corsair Vengeance 1600Mhz
WD Caviar Green 2Tb
Corsair Force 3 90GB
Corsair HX650
Thermaltake Dokker Lite
3x Aerocool Shark Blue
2x Cooler Master Excalibur
Zalman CNPS 9900MAX
Although I had overclocked my CPU, I never touched my video clocks. System and drivers (including the Nvidia ones) are installed on my SSD and everything else on the HDD.
Any clue on what's going on and what can I do to solve this thing?
I indeed reverted my CPU overclock to default settings to no gain, and clearing the CMOS made my VGA POST LED turn on. Now my card is rendered totally useless for it won't display even the EFI.
Thanks for the help. Anyone else has a guess on what's going on?
Updates on the problem:
• After resetting the CMOS and removing/replacing the card like 10 times, I got to have the VGA POSTing again and the mobo LED does not light anymore.
• I ran Driver Sweeper and Revo Uninstaller to wipe away everything, then reinstalled only the graphics drivers (without PhysX, 3d vision and Audio drivers) and... no success. Windows default drivers still work though.
• After installing the Intel Graphics Adapter, my iGPU is able to display my monitor's native resolution.
I have almost no doubt at all that the problem is driver-related. Can there be any problem for my card being a 2GB one?
Thanks
One more update to the problem:
After uninstalling all the drivers, I tried using the computer thru Virtu. CPU-Z now recognizes the 560Ti clock and memory as being from the Graphics 3000, and vice versa.
is there any way to be sure everything is working fine now?
what exactly are you saying, can you elaborate.?
more or less, tell me where you are right now, what is the current status of the unit.?
One picture is worth 1000 threads:
The computer is running fine now, with the monitor plugged into my iGPU port and still running Virtu. I haven't taxed the graphics out yet to see if I am really using my GTX or not.
Updates on the problem once again.
After formatting, clean installing everything, reverting drivers, downclocking the card and everything, nothing worked on definitive.
Sometimes it worked right away, sometimes after a single reboot, but often i had to change back to the iGPU. Uninstalling Realtek Audio drivers made it work for a while, then disabling the Driver Signing worked for a while, then changing the TDR parameters on the registry also worked for a couple of boots but in the end it was all bad again.
Running Cinebench with Virtu enabled gave me a 13 fps mark which is pretty bad, and checking the Virtu Control Panel one can see it does not support Cinebench and not any application I use (CAD). Did not run Tropics though.
So, I decided to move the board from the PCIE 2.0 x16 (blue) to the x8 (grey) one.
fullimage.php
To my surprise it's working a charm! I rebooted like 20 times and did not have a single hang yet. Here's prints from GPU-Z, taken right now as I'm writing this post - do not mind the 32°C idle temperature, I live in Brazil and the room temperature is now ~26°C:
As its running @x8, I decided to run Cinebench and 3dMark (both 11 and Vantage) to see the card performance under load.
At Cinebench I got a stable (10 times) 63.77 FPS in that car chase scene and the temps never went higher than 42°C (I've changed the fan settings on Precision to make it respond almost linearly to the workload).
At 3dMark 11, which ran on the Benchmark only/Performance Settings/Centered (my monitor is a 1050p one), I got a P4718 score. You might see on the linked report that my CPU has been OCed to 4.4Ghz. Temps topped at 57°C at 75% fan.
With 3dMark Vantage, Performance Preset, i got a P19796 score and temperatures topped at 61°C @75% fan.
3d Vision also works fine, though I haven't run any bench on that.
As everything appeared to be normal with those three tests, I tried plugging the card back to the main PCIE blue slot. Once again everything crashed. After switching back to the x8 slot, everything is working properly and the benchmark results were pretty much the same.
Can I say everything is working as it should right now? And what the hell might be causing the crash on the x16 slot? Maybe I should RMA the board, which is brand new and with the newest stuff installed.
Thank you all for the responses!
1.) clean the pci x16 lane with a good cloth and compressed air, alcohol on cloth.?
2.) tried a different card in that pci x 16 slot.?
[strike]3.) reset cmos, BIOS.?[/strike]
[strike]4.) numerous driver installs including drive sweeper[/strike]
5.) reformat of HDD with fresh install of windows.?
[strike]6.) determine it only runs in second pci x18 slot.?[/strike]
I can't think of anything else but to return board..
so try another card in the x16 slot.
last resort is to reformat..
* that's a Z68 board correct.?
in the BIOS what options does it give you for video and pci lane management.?
Once again I thank you for your prompt help. About your checklist, lets see:
1) The board was brand out of the box when it started giving trouble, but will try that.
2) Will try that. Will lend a computer from a friend and see if it works, both with the video card on another MB and another video in my MB.
5) I reformatted the computer a lot of times, installing the drivers and other utilities in a myriad of combinations. If I install the Nvidia drivers first it will work... until I decide to install anything else. Never tried installing the video drivers and rebooting the computer 20 times for stability though.
About the BIOS options, here is a page with pretty much everything the UEFI has to offer us: http://www.legitreviews.com/article/1615/4/
What bothers me most is that even if it's really a motherboard problem, it only happens when the Nvidia drivers are installed. When Windows Standard VGA Driver Adapter is working I haven't any startup problem.
More confusion thrown on the issue.
I've plugged in a Quadro FX380 into the PCIE x16 slot. And it worked damn well - without even needing to uninstall the same drivers that make my computer crash.
My Windows now crashes with a black screen, then switches to the pink screen mentioned in the first post, then shows a black screen with a very dim Start Menu button and the clock, then a blue screen with white artifacts, then a black screen with white artifacts. I'll post a video of it if asked. If I reboot the computer a considerable number of times, though, I can get it to work - but if I try to run 3dMark for example it crashes again to a black screen.
I've been praying for a BSOD (wait, who the hell prays for a BSOD?) to show me something to begin my investigation with. After a number of trials, i finally got this:
I've tried a number of TDR registry modifications, from increasing the timeout to changing the level. Nothing works.
Please, any light on that?
OK.
can we try something once more or a little drastic before you start sending back hardware.?
remove all drives but leave the SSD.
then reformat and install clean win 7 64-bit.
make sure you wipe SSD clean before install.
install 560 Ti in the first x16 slot and then proceed with install of OS.
make sure you have an active internet connection..
As I said before, the card runs nice if the only thing installed to the computer is the Nvidia driver, with the HDD ready to use or unformatted. Anything else I try to install (it can be the MB software, any windows update or even Firefox) makes it crash.
Now what would be the point in leaving only the SSD in? I'll need to put the HD into play later anyway.
so now drive sweeper and then reboot in safe mode to fresh install drivers didn't work.?
did trying another card (from a friend or something) work, what happened.?
First thing I ever tried is Driver Sweeper malmental, too bad it does not work either.
The Quadro FX380 I plugged in worked really well, not a single issue in the whole day. Also using the 560Ti in the Quadro's motherboard (which is a P5KPL/1600) worked fine too.
My mind is warping trying to figure out what can cause the problem:
• Drivers: tried installing every version, letting Windows update do the work (it installs the 275.33 version) and everything but no driver work. Standard VGA Adapter works though.
• BIOS and OCing: resetting the CMOS does not help. Running everything on factory clocks does not either.
• Corrputed system/registry: nope. Everything is brand new and out of the box, including Windows. Tried hacking the TDR parameters on the registry to no help too.
• Bad memory: I don't think so. Ran memtest for a couple hours and did not have a single error.
• Heating: nope. Both idle and load temps are within normal thresholds.
• Bad Power: Corsair HX650. Nuff said.
• Bad PCI slot: don't think so. Another card worked well there.
The only thing that solved the problem so far is changing the PCI slot to the x8 one. But as malmental pointed out, it's paying for nothing if I leave it like that.
this making me think it is a power problem
either with the PCIE x 16 slot supplied 75 watt
or your PCIE 6 pins
your 560Ti should be using two 6 pin power connectors
when you plugged in the Quadro how many 6 pin connectors did it use?
because if it only used one which I think most quadros do
but if 560TI worked with both 6 pins in the x 8 then
maybe that is not it
(sorry brainstorming here)
maybe your PCIE x 16 slot is not supplying power properly
I like Mals idea
clean edge connector of 560TI with strong alcohol (90 percent Isopropyl only)
also clean out the PCIe 16 slot
I think that the power pins on the edge connector of 560Ti is not making proper contact with the PCIe 16 slot
really clean the 560Ti edge connector first with pencil eraser then with iso alcohol
just a thought before returning everything for RMA
Did you breadboard you system before setting it up? I know drivers could be an issue, but hardware is pretty sensitive anything can go wrong.
1. Boot up with just your CPU, heatsink, MoBo, and PSU. If it beeps, you're good. If not, it's probably a bad MoBo (or is it PSU?).
2. Add the RAM. If it beeps, you're good. If not, bad RAM.
3. Add the GPU. If it beeps, you're good. If not, bad GPU.
4. Eventually add the other pieces of hardware and boot up. If any issues occur at this point that do not allow for a successful boot, it's either a bad PSU or MoBo.
If the issue cannot be solved, I would start all over and RMA everything. I know it sucks delaying your build for a week or so, but it's better than the frustration and headaches you are going through.
Well I am pretty much ruling out hardware-related errors here.
The Quadro I plugged in does not have any power source connection. Now that's why I don't think it's hardware, even according to your own suggestions above:
• If it was a PSU problem, why does the card, plugged at the very same power connectors, work properly on the other slot? And if it's a slot problem, why does another card works with it? So I guess none of those is the troublemaker.
• What is a 'breadboarded system?' I have no idea. Either way, the only components that can be "bad" here are the MB or the GPU, but both work on different conditions.
About RMAing my whole system, I'd like to say that in Brazil you have to wait a whole month or more to have your stuff analyzed and, if any device is not factory-f*cked up, you have to unpocket enough money to practically buy another brand new hardware. So I'd like to keep RMA (which in practice is not even RMA at all) from being an option here.
Doesn't the STOP code I've posted above help me into my problem?
Thanks anyways.
It's basically a blueprint of your hardware before you place it in your case. It allows you to determine any hardware issues or to just test if your system will work.
So no, I haven't breadboarded my system.
google your error from your BSOD screenshot and this is what I came up with
quote
I have found and fixed the problem today. This is what appears to happen.
during the installation of the most current drivers 100.65 Vista, an OLD file
nvlddmkm.sys is copied into windows/system32/drivers and not the current one
in the install. As a result the new drivers are attempting to access a file
dated 11/2006 instead of 2/2007 ver 7.15.11.0065 which is in the newest WHQL
driver ver 100.65 vista 32.
Fix: Go to windows/system32/drivers and rename nvlddmkm.sys to
nvlddmkm.sys.old. Go to the nvidia directory and find the file nvlddmkm.sy_
and copy it to windows/system32. Using the cmd window (DOS box) type
EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys. When the expansion is complete, copy
the new nvlddmkm.sys to windows/system32/drivers and restart the computer.
Your computer should now work properly.
You will notice that any uninstall and reinstall of nvidia drivers will not
remove the old nvlddmkm.sys file and will not overwrite it with the newer
version. You have to do it manually. I do not know why this happens but who
cares as long it is fixed
that is from Vista
but should be similar procedure for Win7
your error was nVidia BSOD nvlddmkm.sys error
which this refers too
soure - http://forums.techarena.in/vista-hardware-devices/689444.htm
google search page link - http://www.google.com/#sclient=psy-ab&hl=en&source=hp&q=nvlddmkm.sys+bsod&pbx=1&oq=nvlddmkm.sys+&aq=2&aqi=g4&aql=&gs_sm=c&gs_upl=0l0l2l35l0l0l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=d56119e64ef47a&biw=625&bih=847
