Hi,
I've just purchased an eVGA GeForce GTX 560 Ti. I'm going to use it in a new computer but want to re-use my current PSU which is a Thermaltake W0106RU 700W. According to the specs for a GTX 560 Ti, it requires at least 30 amps on the 12 volt rail. The specs for my PSU are as follows:
Output: +3.3@30A,+5V@28A,+12V1@18A,+12V2@18A,+12V3@18A,+12V4@18A,-12V@0.8A,+5VSB@3.0A
I really have no idea what most of that means. However, I'm assuming that +12V(x) is the specs for the 12 volt rail. I see there are 4 of them with 18A each, so does that mean I have 72A on the 12 volt rail, or does it matter that they are listed separately and I'll need a different PSU?
And, for future expansion thoughts, if I have 72A on the 12 volt rail, does that mean I would be able to SLI dual 560 Ti without upgrading the PSU? The potential problem here is that I only have 2 6-pin PCI-E connectors, so maybe I'd have to get a newer one regardless?
I appreciate any help you can offer. Thanks.
Warren
Warren
