Gtx 590 problems
lbg440
12
Hello,
I recently upgraded my system, and got a GTX 590 with the latest drive installed from nvidia.com.
everything is working fine, except i have this strange problem! texts in games appear extremely jagged that I can't read it! and this problem only appears in games!
I don't think the problem is from the display, because I tried another gpu and everything was fine, it only happens with the GTX 590.
How can I fix this?!
Thanks
Some TV's with dedicated VGA input labeled for the PC connection are fickle and want you to use that and not a DVI to HDMI connection, while the picture will look fine the txt will look as you described. Some newer TV's nowadays label an HDMI input as PC input for connection to the vid card on the PC so could just be your TV honestly.
I have, yes, tried both (turning AA on and of) with no luck. Even the games menu texts have the problem. Basically, ALL texts within a game are extremely jagged, I can't read them!
sadly, it did nothing
as odd as it may sound, check your sharpness setting on your tv, slide it toward teh blurrier side some and see if it helps. Mine was looking funky on my tv too, doin that helped alot. Also if your tv has any "smooth motion" type features, try turnin them off. My text can get odd if the background behind the text moves sometimes.
Heads up! noob question coming through. If I connected my PC to my LED TV through the mobo's HDMI output, will my 590 still render the games? Also, is it fine to do so? wont I sacrifice any graphics by doing that?
