GTX 650Ti fans not spinning
Daki
32
Hi guys I just managed to build my PC (finally, so much sweating) , however I noticed that my GPU fans are not spinning is this normal?
What should I do? When I insert the GPU CD it shows me Please install VGA Cards of Asus.
Would going to nvidia and install the latest drivers solve this?
Your BIOS could be setting the PCIe x16 slot as the primary video adapter, and so it won't display your monitor, but I could be wrong. You should be running your video to your card anyways 😀
Glad you got it up and working! Get those drivers on that disc installed!
In Display adapters the Intel HD Graphics 4600 is the only one showing up
So I guess I didn't installed my GPU correctly?
Ndivia graphics drivers gives me the following message
This graphics driver could not find compatible graphics hardware
Oh yes then, didf you plug in the 6 pin pci-e connector into the GPU?
I also just tested to plug my monitor in the GPU card and it doesn't show a signal, however on the motherboard in works
I plugged the PCI-E cable in the graphics card and I do see a green led above it
So my GPU is plugged on the motherboard
and there's the PCI-E cable that goes from the PSU to GTX 650 Ti
CPU: i7 4770k
PSU: XFX 650W Pro
Mobo: Z87 GD65
Dunno what happened but I insert another PCI-E cable into the graphics card and pressed it again to make sure it is
plugged well into the motherboard and now they spin and I can also connect my monitor to the graphics card
Also shows in the display adapters the GTX 650Ti but however now there's no signal with the monitor plugged on the motherboard is this normal?
They are getting installed at very moment thank you for your effort 😀
