GTX 680 SLI Issue: Worse performance than single card!!!
Makaveliii
77
Hi Guys,
I am having a really weird problem right now. I recently purchased 2 different 680's off eBay. They both individually work perfectly fine. However, when they are SLI enabled, the performance is worse than the single card performance.
My Specs:
FX 8320 CPU
GIGABYTE GA-990FXA-UD3 Rev 4 Mobo
Asus GTX 680 Direct CUII OC GPU
MSI GTX 680 Twin Frozr III GPU
EVGA Supernova 750w Bronze
8gb DDR3
Windows 10 x64
I have tried numerous games with SLI enabled, including witcher 3 and fallout 4 but both perform worse than one of my single cards. By worse, I mean about 5 to 10 fps worse.
I know my CPU isn't the bottleneck, because I used to have a GTX 690 which gave me amazing performance and my CPU utilization never goes past 70 or 80. I know it isn't the PSU, because I benchmarked the cards with furmark with both pulling about 100w tdp, and were at 99 percent load, with no problems for about an hour. It isn't the temperatures as the card on top reaches 75degrees celsius max and the one at bottom only 64 through furmark. I tried installing different driver versions, and doing clean installs of them. I tested all the PCIe lanes and they were working fine. I also checked the PCIe bandwidth through GPUz and it was showing @x16 2.0 for both cards. I'm completely at a loss and this is turning out to be the biggest waste of money ever.
I'll try test the cards in sli in a friend's computer, and will try different SLI bridges and swap out the cards into different PCIe slots.
Another thing to note also is that when playing witcher 3 for example, the load on both gpu in sli is only 50% compared to 99 in single GPU mode.
Could it be a defective card? The MSI 680 also never went past 50 load when i first got it but I re-installed drivers (downgraded from 664 to 361) and the card was at 99% for every game/benchmark.
Hi Guys,
Just an update to any one else reading this thread with the same problem and looking for answers/information. I will try 2 different 680s which I will borrow from a relative, to determine if it actually the hardware/GPU itself that malfunctions when in SLI. I will post back with the answers.
Thanks
