Hello all, first post here so sorry if I don't know exactly what to post.
So basically this year I won a voucher for a new Alienware PC. I would never buy their machines myself, but since I was getting one cheap I dove in. My system specs should be in my sig. I can provide a Belarc audit of the machine and a DxDiag.
Now down to the issue: My system should be about to play pretty much any game at maximum settings, as you would see from my specs. However, when playing games I would notice the frames per second taking large variations. I would be running 111 when would suddenly drop to 60, then drop to the 30 - 40 range and alternate anywhere between 30 - 110 fps. Then suddenly, the system hangs for a few seconds and then; bluescreen. The bluescreen mentions that the system failed to retrieve the device driver.
I must add here that several games are crashing on me, weather they be high spec games such as Crysis, or stuff like World of Tanks that should run without no problems. I only have had crashes in game, no slowdown or issues outside gaming.
I found a useful page on the Nividia forums, but I can't get to it because the forums are temporally down. I would based about how to correctly get the driver's working. It would for the exact error I kept coming up with but after following the steps the same problem is present. When the forums are back I'll try to find this page.
Must mention nothing is overclocked or tampered with in a dangerous fashion (to my knowledge).
I'm pretty sure it's not a CPU or memory issue. I think the problem is with either the card itself or it's drivers, the PSU or perhaps my display output.
After throwing down a considerable amount of money on this machine it's very annoying to be having these problems.
Full DxDiag:
System Information
Time of this report: 7/10/2012, 19:37:18
Machine name: JORDAN-ALIEN
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer: Alienware
System Model: Aurora-R4
BIOS: BIOS Date: 02/08/12 15:27:32 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz (12 CPUs), ~3.2GHz
Memory: 8192MB RAM
Available OS Memory: 8144MB RAM
Page File: 2757MB used, 13529MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 680
Manufacturer: NVIDIA
Chip type: GeForce GTX 680
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1180&SUBSYS_096910DE&REV_A1
Display Memory: 4042 MB
Dedicated Memory: 1994 MB
Shared Memory: 2047 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Dell ST2320L_HDMI
Monitor Model: DELL ST2320L
Monitor Id: DELF024
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0013.0142 (English)
Driver Version: 8.17.13.142
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 5/15/2012 11:48:00, 18044224 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-52C0-11CF-E073-64291FC2C535}
Vendor ID: 0x10DE
Device ID: 0x1180
SubSys ID: 0x096910DE
Revision ID: 0x00A1
Driver Strong Name: oem72.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section033:8.17.13.142😛ci\ven_10de&dev_1180
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Sound Blaster X-Fi Xtreme Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_1102&DEV_000A&SUBSYS_11021007&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: t3.sys
Driver Version: 6.10.0000.0209 (English)
WHQL Logo'd: n/a
Date and Size: 7/27/2009 07:50:06, 639512 bytes
Other Files:
Driver Provider: CREATIVE
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (S/PDIF) (Sound Blaster X-Fi Xtreme Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: t3.sys
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: Realtek Digital Output (Realtek High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10280541&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6505 (English)
WHQL Logo'd: n/a
Date and Size: 11/16/2011 20:58:28, 2950632 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0x0
HW Memory: 0
Description: DELL ST2320L-1 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0040&SUBSYS_10DE0969&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.03.0016.0000 (English)
WHQL Logo'd: n/a
Date and Size: 4/18/2012 18:08:03, 188736 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: t3.sys
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Multimedia Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04CA, 0x0027
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Trust Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x145F, 0x0405
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1D26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 6/1/2012 07:19:26, 343040 bytes
| Driver: usbd.sys, 6/1/2012 07:19:26, 7936 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ Generic USB Hub
| | | Vendor/Product ID: 0x04B4, 0x6560
| | | Service: usbhub
| +-+ USB Input Device
| | | Vendor/Product ID: 0x187C, 0x0513
| | | Matching Device ID: generic_hid_device
| | | Service: HidUsb
| | | Driver: hidusb.sys, 11/21/2010 04:23:47, 30208 bytes
| | | Driver: hidclass.sys, 11/21/2010 04:23:47, 76800 bytes
| | | Driver: hidparse.sys, 7/14/2009 01:06:17, 32896 bytes
| | +-+ HID-compliant device
| | | | Matching Device ID: hid_device
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/21/2010 04:23:47, 33280 bytes
| Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/21/2010 04:23:47, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 746.2 GB
Total Space: 943.4 GB
File System: NTFS
Model: ATA ST31000524AS SCSI Disk Device
Drive: E:
Model: HL-DT-ST DVDRWBD CH20N SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 147456 bytes
System Devices
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 0 - 3CB2
Device ID: PCI\VEN_8086&DEV_3CB2&SUBSYS_05411028&REV_07\3&4F11E61&0&82
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 1 - 3CC1
Device ID: PCI\VEN_8086&DEV_3CC1&SUBSYS_05411028&REV_07\3&4F11E61&0&51
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_05411028&REV_07\3&4F11E61&0&61
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 2a - 3C04
Device ID: PCI\VEN_8086&DEV_3C04&SUBSYS_3C048086&REV_07\3&11583659&0&10
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 184704 bytes
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1D3A&SUBSYS_05411028&REV_05\3&11583659&0&B0
Driver: n/a
Name: Intel(R) C600/X79 series chipset PCI Express Root Port 1 - 1D10
Device ID: PCI\VEN_8086&DEV_1D10&SUBSYS_05411028&REV_B5\3&11583659&0&E0
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent Performance Monitoring - 3C46
Device ID: PCI\VEN_8086&DEV_3C46&SUBSYS_05411028&REV_07\3&4F11E61&0&71
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent - 3CA0
Device ID: PCI\VEN_8086&DEV_3CA0&SUBSYS_05411028&REV_07\3&4F11E61&0&70
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 1 - 3CB1
Device ID: PCI\VEN_8086&DEV_3CB1&SUBSYS_05411028&REV_07\3&4F11E61&0&81
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 0 - 3CC0
Device ID: PCI\VEN_8086&DEV_3CC0&SUBSYS_05411028&REV_07\3&4F11E61&0&50
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_05411028&REV_07\3&4F11E61&0&60
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1b - 3C03
Device ID: PCI\VEN_8086&DEV_3C03&SUBSYS_3C038086&REV_07\3&11583659&0&09
Name: Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #2 - 1D2D
Device ID: PCI\VEN_8086&DEV_1D2D&SUBSYS_05411028&REV_05\3&11583659&0&D0
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 6/1/2012 07:19:26, 52736 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 6/1/2012 07:19:26, 325120 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 6/1/2012 07:19:26, 343040 bytes
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 1 Performance Monitor - 3C45
Device ID: PCI\VEN_8086&DEV_3C45&SUBSYS_05411028&REV_07\3&4F11E61&0&9E
Driver: n/a
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1912&DEV_0015&SUBSYS_05411028&REV_02\4&CF0F56&0&00E7
Driver: C:\Windows\system32\DRIVERS\rusb3xhc.sys, 3.00.0008.0000 (English), 9/15/2011 20:15:00, 216064 bytes
Driver: C:\Windows\system32\rusb3co1.dll, 3.00.0004.0000 (English), 9/17/2011 05:04:06, 90472 bytes
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 System Address Decoder - 3CF6
Device ID: PCI\VEN_8086&DEV_3CF6&SUBSYS_05411028&REV_07\3&4F11E61&0&67
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C94
Device ID: PCI\VEN_8086&DEV_3C94&SUBSYS_05411028&REV_07\3&4F11E61&0&4C
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 0 - 3CB0
Device ID: PCI\VEN_8086&DEV_3CB0&SUBSYS_05411028&REV_07\3&4F11E61&0&80
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DDRIO - 3CB8
Device ID: PCI\VEN_8086&DEV_3CB8&SUBSYS_05411028&REV_07\3&4F11E61&0&88
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QuickPath Interconnect Agent Ring Registers - 3CE6
Device ID: PCI\VEN_8086&DEV_3CE6&SUBSYS_05411028&REV_07\3&4F11E61&0&9C
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1a - 3C02
Device ID: PCI\VEN_8086&DEV_3C02&SUBSYS_3C028086&REV_07\3&11583659&0&08
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 0 Performance Monitor - 3C44
Device ID: PCI\VEN_8086&DEV_3C44&SUBSYS_05411028&REV_07\3&4F11E61&0&9D
Driver: n/a
Name: Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26
Device ID: PCI\VEN_8086&DEV_1D26&SUBSYS_05411028&REV_05\3&11583659&0&E8
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1102&DEV_7006&SUBSYS_00101102&REV_00\4&339730CC&0&00E1
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 1 - 3CF5
Device ID: PCI\VEN_8086&DEV_3CF5&SUBSYS_05411028&REV_07\3&4F11E61&0&6E
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C93
Device ID: PCI\VEN_8086&DEV_3C93&SUBSYS_05411028&REV_07\3&4F11E61&0&4B
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 4 - 3CAE
Device ID: PCI\VEN_8086&DEV_3CAE&SUBSYS_05411028&REV_07\3&4F11E61&0&7E
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 3 - 3CB7
Device ID: PCI\VEN_8086&DEV_3CB7&SUBSYS_05411028&REV_07\3&4F11E61&0&87
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 R2PCIe - 3CE4
Device ID: PCI\VEN_8086&DEV_3CE4&SUBSYS_05411028&REV_07\3&4F11E61&0&98
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to PCI Express Performance Monitor - 3C43
Device ID: PCI\VEN_8086&DEV_3C43&SUBSYS_05411028&REV_07\3&4F11E61&0&99
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DMI2 - 3C00
Device ID: PCI\VEN_8086&DEV_3C00&SUBSYS_3C008086&REV_07\3&11583659&0&00
Driver: n/a
Name: Intel(R) C600/X79 series chipset SMBus Host Controller - 1D22
Device ID: PCI\VEN_8086&DEV_1D22&SUBSYS_05411028&REV_05\3&11583659&0&FB
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 0 - 3CF4
Device ID: PCI\VEN_8086&DEV_3CF4&SUBSYS_05411028&REV_07\3&4F11E61&0&66
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_1102&DEV_0009&SUBSYS_00181102&REV_00\5&4DD0C3F&0&0000E1
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 04:23:47, 122368 bytes
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 1 - 3C90
Device ID: PCI\VEN_8086&DEV_3C90&SUBSYS_05411028&REV_07\3&4F11E61&0&48
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 3 - 3CAD
Device ID: PCI\VEN_8086&DEV_3CAD&SUBSYS_05411028&REV_07\3&4F11E61&0&7D
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 2 - 3CB6
Device ID: PCI\VEN_8086&DEV_3CB6&SUBSYS_05411028&REV_07\3&4F11E61&0&86
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Semaphore and Scratchpad Configuration Registers - 3CE3
Device ID: PCI\VEN_8086&DEV_3CE3&SUBSYS_05411028&REV_07\3&4F11E61&0&5B
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 I/O APIC - 3C2C
Device ID: PCI\VEN_8086&DEV_3C2C&SUBSYS_05411028&REV_07\3&11583659&0&2C
Driver: n/a
Name: Intel(R) C600 Series Chipset SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_2826&SUBSYS_05411028&REV_05\3&11583659&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStorA.sys, 3.00.0000.2003 (English), 10/12/2011 23:44:00, 562456 bytes
Driver: C:\Windows\system32\DRIVERS\iaStorF.sys, 3.00.0000.2003 (English), 10/12/2011 23:44:02, 23832 bytes
Name: Intel(R) C600/X79 series chipset High Definition Audio Controller - 1D20
Device ID: PCI\VEN_8086&DEV_1D20&SUBSYS_05411028&REV_05\3&11583659&0&D8
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_05411028&REV_07\3&4F11E61&0&6A
Driver: n/a
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_05411028&REV_06\4&5964FA1&0&00E3
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C84
Device ID: PCI\VEN_8086&DEV_3C84&SUBSYS_05411028&REV_07\3&4F11E61&0&44
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 2 - 3CAC
Device ID: PCI\VEN_8086&DEV_3CAC&SUBSYS_05411028&REV_07\3&4F11E61&0&7C
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 3 - 3CB5
Device ID: PCI\VEN_8086&DEV_3CB5&SUBSYS_05411028&REV_07\3&4F11E61&0&85
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Interrupt Control Registers - 3CE0
Device ID: PCI\VEN_8086&DEV_3CE0&SUBSYS_05411028&REV_07\3&4F11E61&0&58
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Control Status and Global Errors - 3C2A
Device ID: PCI\VEN_8086&DEV_3C2A&SUBSYS_05411028&REV_07\3&11583659&0&2A
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_05411028&REV_A5\3&11583659&0&F0
Name: Intel(R) C600/X79 series chipset PCI Express Root Port 8 - 1D1E
Device ID: PCI\VEN_8086&DEV_1D1E&SUBSYS_05411028&REV_B5\3&11583659&0&E7
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_05411028&REV_07\3&4F11E61&0&69
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C83
Device ID: PCI\VEN_8086&DEV_3C83&SUBSYS_05411028&REV_07\3&4F11E61&0&43
Driver: n/a
Name: NVIDIA GeForce GTX 680
Device ID: PCI\VEN_10DE&DEV_1180&SUBSYS_096910DE&REV_A1\4&2E917B5E&0&0018
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 232768 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/15/2012 11:48:00, 1066872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_4e3c5699d87cafeb\NvCplSetupInt.exe, 1.00.0001.0000 (English), 5/15/2012 11:48:00, 71931424 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 285504 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 3/22/2012 17:44:00, 4096 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 220480 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 316928 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 3/22/2012 17:44:00, 4096 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 249856 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 3/22/2012 17:44:00, 21887 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 5/15/2012 11:48:00, 61248 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 5/15/2012 11:48:00, 68928 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 14298944 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 1.00.8171.30142 (English), 5/15/2012 11:48:00, 333120 bytes
Driver: C:\Windows\system32\nvapi64.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 2741568 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 25248064 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 8139072 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 6.14.0013.0142 (English), 5/15/2012 11:48:00, 2881856 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 2681664 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 18044224 bytes
Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 364352 bytes
Driver: C:\Windows\system32\nvinfo.pb, 5/15/2012 11:48:00, 14324 bytes
Driver: C:\Windows\system32\nvinitx.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 246592 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 25743168 bytes
Driver: C:\Windows\system32\nvumdshimx.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 949056 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 10194752 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 1.00.8171.30142 (English), 5/15/2012 11:48:00, 282432 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 2368832 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 17551680 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 5982528 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 6.14.0013.0142 (English), 5/15/2012 11:48:00, 2445120 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 2524992 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 15322432 bytes
Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 301376 bytes
Driver: C:\Windows\SysWow64\nvinit.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 202048 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 19607872 bytes
Driver: C:\Windows\SysWow64\nvumdshim.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 818496 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.17.0013.0142 (English), 5/15/2012 11:48:00, 8105280 bytes
Driver: C:\Windows\system32\nvdispco64.dll, 2.00.0025.0002 (English), 5/15/2012 11:48:00, 1738048 bytes
Driver: C:\Windows\system32\nvgenco64.dll, 2.00.0014.0002 (English), 5/15/2012 11:48:00, 1468224 bytes
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 1 - 3CAB
Device ID: PCI\VEN_8086&DEV_3CAB&SUBSYS_05411028&REV_07\3&4F11E61&0&7B
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 2 - 3CB4
Device ID: PCI\VEN_8086&DEV_3CB4&SUBSYS_05411028&REV_07\3&4F11E61&0&84
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 3 - 3CD0
Device ID: PCI\VEN_8086&DEV_3CD0&SUBSYS_05411028&REV_07\3&4F11E61&0&53
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Address Map, VTd_Misc, System Management - 3C28
Device ID: PCI\VEN_8086&DEV_3C28&SUBSYS_05411028&REV_07\3&11583659&0&28
Driver: n/a
Name: Intel(R) C600/X79 series chipset LPC Controller - 1D41
Device ID: PCI\VEN_8086&DEV_1D41&SUBSYS_05411028&REV_05\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_05411028&REV_07\3&4F11E61&0&68
Driver: n/a
Name: Intel(R) C600/X79 series chipset PCI Express Root Port 4 - 1D16
Device ID: PCI\VEN_8086&DEV_1D16&SUBSYS_05411028&REV_B5\3&11583659&0&E3
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 0 - 3C80
Device ID: PCI\VEN_8086&DEV_3C80&SUBSYS_05411028&REV_07\3&4F11E61&0&40
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_096910DE&REV_A1\4&2E917B5E&0&0118
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 0 - 3CAA
Device ID: PCI\VEN_8086&DEV_3CAA&SUBSYS_05411028&REV_07\3&4F11E61&0&7A
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 1 - 3CB3
Device ID: PCI\VEN_8086&DEV_3CB3&SUBSYS_05411028&REV_07\3&4F11E61&0&83
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 2 - 3CC2
Device ID: PCI\VEN_8086&DEV_3CC2&SUBSYS_05411028&REV_07\3&4F11E61&0&52
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode - 3C08
Device ID: PCI\VEN_8086&DEV_3C08&SUBSYS_3C088086&REV_07\3&11583659&0&18
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_05411028&REV_07\3&4F11E61&0&62
Driver: n/a
Name: Intel(R) C600/X79 series chipset PCI Express Virtual Root Port - 1D3E
Device ID: PCI\VEN_8086&DEV_1D3E&SUBSYS_00008086&REV_05\3&11583659&0&88
Name: Intel(R) C600/X79 series chipset PCI Express Root Port 2 - 1D12
Device ID: PCI\VEN_8086&DEV_1D12&SUBSYS_05411028&REV_B5\3&11583659&0&E1
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller RAS Registers - 3C71
Device ID: PCI\VEN_8086&DEV_3C71&SUBSYS_05411028&REV_07\3&4F11E61&0&79
Driver: n/a
Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Registers - 3CA8
Device ID: PCI\VEN_8086&DEV_3CA8&SUBSYS_05411028&REV_07\3&4F11E61&0&78
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
VDP Renderer,0x00200000,1,0,vdpsnka.dll,3.00.0002.0298
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Digital Audio (S/PDIF) (Sound B,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Sound Blaster X-Fi Xtreme Audio S/PDIF-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio Mic-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Sound Blaster X-Fi Xtreme Audio Line-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio S/PDIF-Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio Line-Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
VDP Source,0x00200000,0,1,vdpsrca.dll,3.00.0002.0298
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Sound Blaster X-Fi Xt,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DELL ST2320L-1 (NVIDIA High Def,0x00200000,1,0,quartz.dll,6.06.7601.17713
Digital Audio (S/PDIF) (Sound B,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: DELL ST2320L-1 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Digital Audio (S/PDIF) (Sound Blaster X-Fi Xtreme Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Sound Blaster X-Fi Xtreme Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Full DxDiag:
System Information
Memory: 8192MB RAM
DxDiag Notes
Display Devices
Monitor Id: DELF024
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x10DE
Device ID: 0x1180
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: t3.sys
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: t3.sys
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Driver Name: t3.sys
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
USB Devices
+ USB Root Hub
| Service: usbhub
+-+ Generic USB Hub
| | Service: usbhub
| +-+ Generic USB Hub
| | | Service: usbhub
| | | Service: HidUsb
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Drive: C:
File System: NTFS
Drive: E:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
PBDA CP Filters:
Midi Renderers:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
BDA CP/CA Filters:
Audio Renderers:
Quality Flags: 2576
Enabled:
Force throttling
Allow scaling
Enabled:
Force throttling
Allow batching
Force scaling
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
