GTX 745 / Monitor Compatibility
MikesterAZ
Hi, I purchased one of these 30" monitors from eBay and it has some specialized compatibility requirements listed in the description:
http://www.ebay.com/itm/121296923082?euid=95d706ad546f48a3948bd0b93d90d975&cp=1&exe=12808&ext=32575&sojTags=exe=exe,ext=ext
I am trying to determine if it is compatible with the GTX 745 that is factory installed in the Dell XPS 8700.
I had a lot of issues trying to upgrade my HP Envy 700-410 to accomodate, we put in a GTX 750ti and it worked at first but then I lost primary display .... (think it was some kind of power supply issue though we did put a larger one in) ... Finally gave up on that configuration, sending the Envy back and looking for something that works with the monitor.
Please don't be distracted by the backstory about the Envy / 750 ........ That ship has sailed, it is boxed up and going back already. I am looking at how to move forward.
The Dell 8700 is one of the few in my price range (~$1000) that includes a graphics card. I don't want to fuss with upgrading one on arrival but I may have to.
So, will the GTX 745 work out or do I need to figure something else out? And if so, does this community have any recommendations?
What is exactly your question.
GTX 745 (OEM) GPU Engine Specs:
CUDA Cores - 384
Base Clock 1033(MHz)
GTX 745 (OEM) Memory Specs:
Memory Clock - 1.8 Gbps
Standard Memory Config - Up to 4 GB
Memory Interface - DDR3
Memory Bandwidth - 28.8(GB/sec)
GTX 745 (OEM) Support:
OpenGL - 4.4
Bus Support -PCI Express 3.0
Certified for Windows 7, Windows 8, Windows Vista or Windows XP - Yes
Supported Technologies(1) - CUDA, DirectX 12, PhysX, TXAA, FXAA, Adaptive VSync, G-SYNC-ready, 3D Vision
3D Vision Ready - Yes
Microsoft DirectX - 12 API
Blu Ray 3D - Yes
3D Gaming - Yes
3D Vision Live (Photos and Videos) - Yes
Display Support:
Multi Monitor - 3 displays
Maximum Digital Resolution(2) - 4096x2160
Maximum VGA Resolution - 2048x1536
HDCP - Yes
HDMI - Yes
Standard Display Connectors - Dual Link DVI-D, HDMI, VGA
Audio Input for HDMI - Internal
GTX 745 (OEM) Graphics Card Dimensions:
Length - 5.7 inches
Height - 2.7 inches
Width - Single-width
Thermal and Power Specs:
Maximum GPU Tempurature (in C) - 95
Graphics Card Power (W) - 55
Minimum System Power Requirement (W)(3) - 300
1 - NVIDIA G-SYNC requires a NVIDIA G-SYNC-ready monitor. Applicable for DisplayPort-enabled graphics cards.
2 - 3840x2160 at 30Hz or 4096x2160 at 24Hz supported over HDMI. 4096x2160 (including 3840x2160) at 60Hz supported over Displayport. Support for 4k tiled MST displays requires 326.19 driver or later.
3 - PCs with the GeForce GTX 745 (OEM) may be qualified by the manufacturer to run at lower power supply than noted above. Please consult your PC manufacturer for details.
"What is exactly your question."
Really?
"So, will the GTX 745 work out or do I need to figure something else out? And if so, does this community have any recommendations?"
Silly me, asking a detail technical question on a tech forum and providing all the details in the OP.
What was I thinking?
Hold on, slow down, as I am trying to understand your exact question.
So you are asking - if you purchase XPS 8700, basic configuration, will your screen work with it - the answer, yes, it will, it is covered by resolution. It would be plug and play. That is why I provided complete specifications previously.
What concerns me is the purpose - are you planning to play games with your setup, or just simple video watching and similar and regular office tasks?
For gaming GTX 745 is weak and stronger card will be required. XPS 8700 can support up to GTX 960 without power supply upgrade, which would be good for casual gaming. However, XPS BIOS must be version A10 or higher for GTX900 series support.
Did I answer your question, or I missed something?
Kisianik, you are a much more patient, understanding and kind individual then I.
Hi,
I'm really confused by this: 1 - NVIDIA G-SYNC requires a NVIDIA G-SYNC-ready monitor. Applicable for DisplayPort-enabled graphics cards.
I might have totally misunderstood, but it seems to me that the GTX_745 does not have a display port (right?) - but the OEM specifications list it as G-SYNC-ready (cf. links below)
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-745-oem/specifications
http://www.geforce.com/hardware/technology/g-sync/faq#q3
So, if the graphics card doesn't have a display port, and a display port is required for G-SYNC, how can it be G-SYNC-ready? Any thoughts/explanations would be appreciated!
Cheers
