gtx 960 vs gtx 970 vs gtx 980, whats the difference other than fps?
DARK__
26
I mean, will I be getting more clear, good & real image than gtx 960 in gtx 970??.
Also similarly more clear, good & real image than gtx 970 in gtx 980??
Also similarly more clear, good & real image than gtx 980 in gtx 990?? and so on......??
OR
There would be only fps difference??
(960<970<980 & so on....)
At that level, you're starting to see diminishing returns on FPS per dollar spent.
Here's a chart that shows the performance per dollar spent. The website gets a ton of benchmarking data you can sift through but this chart shows the performance per dollar spent.
http://www.videocardbenchmark.net/gpu_value.html
The more money you spend, the less of an increase you'll see in performance per dollar.
You obviously have to weigh that against the performance you're looking for.
Here's a robot woman talking about the difference in performance between the top NVIDIA cards:
https://www.youtube.com/watch?v=fQap4VGLpvU
Personally, I think the 960 and 970 are the best performance per price point and that's only if you have a monitor or monitors that gives you over 60 FPS. Higher than that, you're paying a butt load for a performance increase you're not likely to see unless you have other parts of your rig that match that level of performance.
