GTX780 6GB power supply
And by okay you mean that there is enough breathing space for things like led's and fan controllers too ?
Your all set with the GS 700 more than enough.
Requirements : GTX780 6GB
Minimum of a 600 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 42 Amps.)
An available 6-pin PCI-E power connector and an available 8 pin PCI-E power connector
Total Power Draw : 250 Watts
http://www.youtube.com/watch?feature=player_embedded&v=beEICnh137A
EVGA.COM
oh well i think that means that i will need to upgrade my psu in order to get the almighty GTX 780 . i think i will go for the rm1000 cause its only 20 dollars more expensive than the one you mentioned . thank you
actually i live in Dubai which means that in order to get the RM1000 i need to pay almost 250 dollars 🙁
I prefer to buy it from stores here in dubai . but i dont mind buying it from amazon if i cant find it here .
