Silverion77 :
Its Jedec standard.....its like that for all motherboards with DDR2
Thats pretty much explains it. So if my ram is rated at 2.1v I should have the setting to +.3? I'd also like to ask if it helps with stability to set it higher? I had initially set the memory timings to 4-4-4-12, which my ram is rated at, but I didn't know what the default voltage on the board was so I didn't make any changes. Once I started o/c, I relaxed to the timings to 5-5-5-15, but haven't changed them back. Would raising the voltage to 2.1 and lowering the timings again be better? I'd assume so, but this is my first time o/c'ing.
