Hello! I would like some advice on what to upgrade so that I can get smooth and consistent frame rates on Guild Wars 2, with graphics on high settings.
I'd like 35 fps at minimum in most situations. However, I'm also willing to accept frame drops in heavily populated areas, but no lower than 20 fps.
Ultra settings would be nice, but not if its a huge price difference. The cheaper I can do this upgrade, the better.
I have an HP/Compaq CQ5210f.
No hardware has been changed, except for the graphics card bought shortly after the computer.
**Windows 7 Home Premium 64-bit service pack 1
**Athlon II x2 215, 2.70 GHz processor (65w)
**Phoenix Technologies 5.49 BIOS
**3GB DDR2 SDRAM memory (400 mhz)
**M2N68-LA Narra5-GL6 motherboard
**ST350041 8AS SCSI Disk Device (500gb, 7200 rpm)
**250w power supply
More detailed specs are listed here, including acceptable processor and memory upgrades:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01859813&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4005896
This my graphics card:
**single Radeon HD 4650, uses PCI-E x16 (pci and pci-e x1 are also available slots)
**1gb GDDR3 memory w/ 500mhz clock
**600 mhz core clock, 55nm chip, bus width 128 bits, 320 unified shaders, GPU rv730 (etc)
This might be overkill on spec info, but I figured better more info than need to add later.
I look forward to hearing advice and suggestions for upgrades.
**250w power supply
