The H500 is expected to be released in Q3, so I was wondering what is the best fan setup for it. At the convention, the case had the top 3 fan slots as 3x 120mm intakes, the front 2 as intake and only 1 140mm exhaust. Would this setup provide good airflow? Or should I have the top 3 as exhaust so I get negative pressure? I would be using an air cooler just so you know but I also don't know which air cooler to pick, I would be ok with getting an NH-D15 but it's quite ugly and I don't think that it would go well with a full RGB build.
