HAF-X I/O Front Panel Replaced...Ground wire?
thenyrfan
9
I just replaced my HAF-X I/O front panel, and there is one wire on the new one that the old one did not have. I am wondering what it is for?
It appears to be a grounding wire I assume? If so how exactly would I ground it? The wire is pretty short, and I don't know where to ground it to. As many of you know the Haf-X is textured painted steel, not exposed aluminum, am I too mount it to the nearest screw hole and fasten it to the case with a screw? What if I cannot reach the closest hole?
It's a grounding wire. Just secure it with a screw in one of the holes right underneath on the metal frame.
Also holy bump!
edit:
I actually found a few pics I took way back when, when I first encountered this issue.
IIRC, I ended up mounting it to the hole where the red arrow is. I believe I first initially mounted it to the 5.25 drive bay seen in the 2nd pic, but if I recall it didn't leave much slack when snapping the panel back on.
