Hard drive adapter kit
beauknowsdiddly
414
21
18,815
I have a toshiba satellite m35x-s161 that I'm thinking I need to replace the power jack, the thing just keeps shutting down. but in the mean time I need to get the data off the hard drive. Apparently it's a 60 GB eide drive
model# IC25N060ATMR04-0. I can't seem to find an adapter kit that'll fit it so that I can hook it up to my desktop and retrieve the data. I've found a few but none of them look like they'll fit. Like this one
http://www.google.com/products/catalog?hl=en&q=laptop+hard+drive+adapter&um=1&ie=UTF-8&cid=6920772235798267606&ei=_hDRS-SQE4iM8wTK35y2Dw&sa=X&oi=product_catalog_result&ct=image&resnum=3&ved=0CCkQ8gIwAg#
Can someone please help me find the correct adapter kit?
Thank You
BeauKnowsDiddly
Oh I see, When I pulled the Hard drive out the little adapter thingy from the laptop came out still connected to it. So I pulled that off and it's just a standard 44 pin connector, so I'm thinking that adapter I gave you the link for should work. Ya think?
