Hard Drive not reporting right info
Tall Paul
6
HD storage going down. I have taken off 10 gm off. HD storage space is not changing at all. I ran 5 HD programs to check HD out. drive is good no eres or bad news at all. If I put a a file on that is 500kb,then HD will show that 500kb drop in space. So I take off the 500kb file and HD space will not come back. Have been at this for a week now. On PC for 15+years now..
Thanks for Any Help
Hi there Tall Paul,
You can start the troubleshooting process with scanning your system with some anti virus/malware tool.
After that, you can run disk cleanup as well as delete temporary files. You can check out your System Restore settings as well.
Check these out: http://www.howtogeek.com/125923/7-ways-to-free-up-hard-disk-space-on-windows/
Hope this will help,
D_Know_WD
More from Tall Paul
Took off about 22gb,and HD did not move..in reporting. (same) I put a small file on and it went down again in storage.
HD,WD,320gb, PC,Only reports files going on, and not coming off. I did not know it was doing this..I had a lot of updates put on about a month ago ?? * MSN, XP, updates has been off for years.
My Defrag programs stop working at about 92 GB, now at 46 GB yesterday. This is how I found out I had a problem. I ran my Defrag program yesterday from Win XP, after it stopped after a few minutes, but it did not Defrag anything, the report I got back said I had, Free space = 243 GB, Percent free space = 82 %..
Went to (MY computer) It said 46 gb, File manger,and other programs for H Drive have been and are still on the low side .. time to clean and reinstall and hope that is the end of it. Thanks for UR help
