Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Can anyone give me some advice about a problem that has occurred on my
brother's PC.
The other day he had to swap power connecters on a number of peripherals in
his PC. When he disconnected the power connecter from his primary disk
drive, one of the 4 power pins on the drive came away (probably broke) and
remained inside the plastic connecter.
Do you know of any way in which this could be repaired without costing a
fortune. He just wants to be able to power up the drive in order to be able
to retrieve a number of documents and files - then the drive will be thrown
away and replaced.
Although he does back up his key files fairly regularly, he reckons there is
a month's worth he would lose if he cannot access the drive.
Has anyone had a similar problem and successfully made a temporary fix?
Thanks.
Harry
brother's PC.
away and replaced.
Thanks.
Harry
