hard drive problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
recently had a crash and after reloading xp and getting everything reloaded i
now seem to have 2 hard drives and am constantly getting pop up warning of
low space on " f " drive and my hard drive should be on " c " drive what is
causing this and what can i do to fix thanks
Sounds like your reinstallation of XP resulted in a second copy being
installed in a different partition. Open Explorer, look at the different
drives and report back.
"lynn yeomans" <lynn yeomans@discussions.microsoft.com> wrote in message
news:46A84654-653F-4A53-9637-8B4AB160A945@microsoft.com...
> reloaded i
> is
> reloaded i now seem to have 2 hard drives and am constantly getting
> pop up warning of low space on " f " drive and my hard drive should
> be on " c " drive what is causing this and what can i do to fix
> thanks
Sounds to me like you had an external Zip (or similar) drive attached during
the installation. You should have disconnected all peripherals during
installation. You will now have to reinstall clean with the drive removed.
Facon - the artificial bacon bits you get in Pizza Hut for sprinkling
on salads.
You are a true troll.You never have anything
constructive to say and you are always critical of others. Read some of your
posts. Your posts are mostly, if not all pure garbage. They speak for
themselves. Check them out. It seems most people agree with me.
http://tinyurl.com/5ly92
http://tinyurl.com/5msfx
"Miss Perspicacia Tick" <misstick@lancre.dw> wrote in message
news:_aLpd.2428$xt.1641@fe48.usenetserver.com...
>> thanks
> during the installation. You should have disconnected all peripherals
> during installation. You will now have to reinstall clean with the drive
> removed.
> on salads.
> of your posts. Your posts are mostly, if not all pure garbage. They
> speak for themselves. Check them out. It seems most people agree with
> me. http://tinyurl.com/5ly92
Jim,
I don't see you posting anything other than this drivel. All your posts are
being forwarded to my contacts within MS and, hopefully, in a very short
time you should be banned from posting. You won't be the first person I've
had permanently excluded from these groups and you sure as Hades won't be
the last!
on salads.
> Jim,
> the last!
you just proved Jim's point
