Question Hard Drive Problems?
Aug 5, 2019
13
So my PC has a 1TB Western Digital hard drive, but the computer shows only 120GB of storage available, I’m new to computers and Im not sure what to do or if something is wrong. This PC was pre-built, it’s an Inspiron 5680 btw
Can you show us a screenshot from disk management?
Press WIN+X --> Disk Management
And what tells you it is supposed to be a 1TB WD drive?
That looks like a 128GB drive.
Have you opened the case and eyeballed the drive in question?
Yes, I opened the PC and checked everywhere until I saw what looked like where the hard drives go, and sure enough, it was a 1TB WD hard drive I physically saw it
So...
Disk Management shows a single 128GB drive, probably an SSD.
Eyeball shows a single 1TB HDD.
Speculation:
A physical 128GB SSD you've not seen, and a possibly disconnected 1TB HDD.
Under Device Manager, Disk Drives, it shows "Liteon CV8-8e128-11 sata 128gb" but no 1TB HD
Could be a hidden M.2 perhaps.
Make sure the 1tb hdd is connected. It is not showing up in your system.
I thought i saw the 1tb drive but what i saw was a 1gb partition.
From what I've seen, there are 2 cables connected to it, one that's a couple of wires grouped together which might be the power from what I've researched, and a blue cable.
Unplug both cables and plug them back in. Make sure the smaller data cable feels like it clicks into place.
There should be the other end of the data cable that plugges into your motherboard. Take that out and put it back in.
Could be a dead drive too.
I plugged them back in, even applied a small amount of pressure to them to make sure. On a related or unrelated matter I also saw a red and black cable not connected to anything, it’s just dangling and it says “P4” on where it should connect to something.
I tried taking a picture on my phone, importing it to the PC, and using the website someone mentioned but it didn't work. The connector of the red and blue cables look almost exact to the one connecting to the HD
red and black! im sorry my bad i meant to say the red and black cables look almost exactly to the blue one connecting to the HD
Good, your bios sees the drive at least.
Does disk management show it now?
I'm really late but I wanted to give a quick update, it was the actual hard drive that wasn't working. I went ahead and bought a new one (Western Digital 1TB Blue) but I forgot to buy a SATA cable so I just decided to connect the one that was connected to the one in the HD that I was having issues with to test the cable and sure enough it worked. Formatted the HD and now it's up and running and I've even installed some games I've always wanted :)
--1st try to run it upside down and on each side. Maybe the bearings wore a certain way? I found turning it suddenly the way the disks turn helps and then trying to either stop suddenly or gently worked.
--Put the old one in the freezer for 10mins or so. Give the old one a bang when it;s installed. About half the time i found the drive will work long enough so you can get the files off. If not sometimes overnight in the freezer worked too. ----Im gonna assume you wanted your stuff off of it...
